why is my speedometer acting crazy
when accelerating my speedometer needle is acting very strang. it nevers stays at one speed when im driving. for example ill be doing 70 on the highway and my needle will be going all over the place. what is this?
Re: (smokee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokee »</TD></TR><TR><TD CLASS="quote">do a search for VSS or vehicle speed sensor</TD></TR></TABLE>
i 2nd
i 2nd
Re: (powerfulperformance)
mine some time sticks at 0 and when i hit it like tap when driving it plops up to like 20
some times i can tell its not acurate giving it gas and not moving for a few seconds
so my symptoms are a retarted or slow speedo how can i fix this?
Re: (my si is bluer than yours)
man you guys really need to learn basic troubleshooting!
never replace a part outright.
its very common for the VSS to have corrosion and contact problems, the symptoms you describe are very accurate with this
unplug the VSS, clean the connectors with electrical parts cleaner, let it dry, try again.
Re: (lazybrown187)
i had that verry same prob i fixed mines i have a b16 trans in a eg i took it out pop out the lil pin clean up the shaft put some gear oul on it and put it back in make sure therres no dirt in the sensor it self where it connect to the harness then try it it worked out pretty good for me
like everyone else has said, check your VSS first, if not, take out your cluster and and push the speedo needle up, should have some resistance and go back down. if you push it up and it goes all the way around, then you my friend need a new cluster
