D16y8?
D16y8?
if i put a D16y8 motor will i get about 230hp with a ported and polished head and a skunk2 cam gear, p20 ECU with hondta, and then go turbo? or would i get more power by doing a mini me with putting the y8 head on my y7 block and doing all of the same work?
thanks,
Curbow_USMC
SemperFi
thanks,
Curbow_USMC
SemperFi
Re: D16y8? (haveaniceday)
230WHP shouldn't be that hard with the right turbo. i've got the greddy kit on my a6/z6 and at 12 psi i put down 218 to the wheels and my turbo is tiny!
Location: We Cant Stop Here This Is Bat Country, So CaL, USDM
Re: D16y8? (douspray)
230whp out of a NA Y8 is gonna cost $10K.
You would need a cam that only idles at 2K RPM and a 13K RPM redline
now a boosted Y8 could do it, not on stock internals for very long though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haveaniceday »</TD></TR><TR><TD CLASS="quote">i suggest the ex transmission .. then the head .. the head alone gains will probably be worthless .. or just tranny then boost </TD></TR></TABLE>
I agree... do the transmission first then go from there.
Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">Just turbo your engine now and drop an EX transmission.</TD></TR></TABLE>
Yup, VTEC is overrated. If you have it already, great. If you don't, who cares.
Re: D16y8? (Kista20)
would i not just come out better getting a whole y7 and tranny? and also if i build and at least port and pollish and put a skunk2 cam gear will the valve trann hold up 6-8 bls of boost?
Re: D16y8? (Curbow_USMC)
well putting 230 to the wheels, its impossible! Well maybe for the first 10 runs!! You will tear your internals up with out a full rebuild! Your stock internals are only made to handle soo much, think about it, research, it'll make you think more, and more, and more. Eventually you get answer! (someday)
I hope your talking about using a Turbo cam, if you're talking about a skunk2 stage 1,2....etc cam then your not gonna make that kind of power. The profiles of those cams will **** you up.
crxnightrider
05-20-2007 12:44 PM
awdriscol4
28
03-05-2005 10:13 PM
