B18B1 Bad Gas Milage
Old 08-16-2005, 07:15 PM
Daniel-sanB1's Avatar
Default B18B1 Bad Gas Milage
well I did search, found a lot of useless threads and found 0 answers.
I just recently swapped a B18B1 in my 92 hatch.
I though this engine was in mint shape, but it obviously was a POS.
the Head was rebuilt with OEM parts, but the bottom was untouched. and it burns a lot of oil. anyways...
I'm getting about 300KM per tank, that's 186Miles per tank.
my hatch is a DX, so it does have the bigger tank that has 40 Liters.
this is stupid, I'm getting garbage garbage mileage.
when i got my car out of the shop. I drove my car pretty hard and I managed to get 450KM out of it or 280miles.
but that was my first tank. since then Ive filed it up 6 times, and I always get around 300. I drove like a bitch and got 330 this pass tank.
everything is stock cept for a EBay short ram intake. stock exhaust.
please help me out, this is insane with the price of gas lately.
** Cliff notes
getting 180miles per tank on my EH2 B18B1
Old 08-16-2005, 07:17 PM
Electrician
Deemeetree's Avatar
What is the condition if your o2 sensor and catalytic converter?
Old 08-16-2005, 07:27 PM
Default Re: (Deemeetree)
13 years old I guess
o2 sensor is on the exhaust manifold right ? so.. that should be 9 years old since it came with my 96 B18
Old 08-16-2005, 07:28 PM
Electrician
Deemeetree's Avatar
Are you throwing any CELs? Maybe it's time for an overhaul on the O2 and cat. Maybe you need a tune-up. Maybe your timing is off.
It could be a number of things.
Old 08-16-2005, 07:37 PM
engine should be tuned up
engine was installed at a reputable shop (since it wouldn't start when I put it in)
(8 bent valves)
they replaced 8 of the valves, 3 angles valve job, head gasket, water pump. and timing belt.
I'm throwing no cels
I do want to get a new exhaust system to get it flowing a bit nicer, but I kinda out of money and don't want to waist it on anything that I don't REALY need right now.
I jsut though it was weird that I got 450KM on my first tank when I first got the car. and then **** mileage after that
Old 08-16-2005, 07:39 PM
Electrician
Deemeetree's Avatar
I only get 300 miles per tank on a BONE STOCK D15B7. Oh yes, my O2 and cat are gone to ****.
Check those things.
Old 08-16-2005, 07:41 PM
alright, I'll get a flowmaster exhaust or something
sea foam the ****** and get a new O2 sensor.
I'll try those and update this post
Old 08-16-2005, 07:56 PM
blackeg's Avatar
Default Re: (Daniel-sanB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel-sanB1 &raquo;</TD></TR><TR><TD CLASS="quote">alright, I'll get a flowmaster exhaust or something
I'll try those and update this post</TD></TR></TABLE>
damn good start. also try little things like new spark plugs. even though you said it should have been tuned up, plugs are still only a few dollars each
Old 08-17-2005, 06:47 AM
Default Re: (blackeg)
I'll try that too
but I got the wires off my buddy's 99 teg, and his wires were already changed, so I'm assuming they're pretty new.
Old 08-17-2005, 08:28 AM
tpr
tpr's Avatar
using the gas gauge as the method of checking fuel mileage is inacurate. When you next fill the car reset the trip meter. Drive it till at least 3/4 of the tank is empty. fill it back up and record gallons (liters) and devide the miles by the gallons = MPG. the fuel gauge may be degrading and becoming less and less accurate. Use the trip meter and it should be much more accurate.
Old 08-17-2005, 08:40 AM
D15Bbigred's Avatar
well i've heard a full gas tank gets better gas mileage than a somewhat empty tanks, IE: 1/4 - to dead empty, any truth too that
Old 08-17-2005, 08:58 AM
EK k kay's Avatar
Default Re: (EJ1D16Z6)
^I don't know about that, but my fuel gauge moves much faster after passing the half way mark. While driving normally on a full tank I can get around 100 mles before the needle starts moving at all.
Old 08-17-2005, 09:06 AM
tpr
tpr's Avatar
No truth to that at all. The opposite is true. The less fuel voulm in the car the lower the weight. So in theory it should get slightly better fuel economy. But it may not be measureable.
Old 08-17-2005, 10:46 AM
Default Re: (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">using the gas gauge as the method of checking fuel mileage is inacurate. When you next fill the car reset the trip meter. Drive it till at least 3/4 of the tank is empty. fill it back up and record gallons (liters) and devide the miles by the gallons = MPG. the fuel gauge may be degrading and becoming less and less accurate. Use the trip meter and it should be much more accurate.</TD></TR></TABLE>
that's what Ive been doing every time I fill up my gas tank
I get 300Km per tank with 87oc gas
I jsut finished my tank of 89, and got 360 ish
I'll try 91, but that's still not fixing my problem
Old 08-17-2005, 11:32 AM
tpr
tpr's Avatar
Check your ignition timing and TPS for proper settings. Does it have the same amount of power. What is your cold compression? it should be at least 120-180 PSI with less than 5-10% variation cylinder to cylinder.
unknown0001
10
04-10-2005 02:56 PM
91_HB
03-22-2005 03:24 PM
Sephro
03-12-2003 07:34 AM
FourthGenHatch
02-25-2003 07:40 PM
garrybloom
07-21-2002 05:45 PM
Quick Reply: B18B1 Bad Gas Milage
