where does this vacuum line go to?
Re: where does this vacuum line go to? (delsol10psi)
yeah it used to be turboed and that line went to check valves but they were sold with the kit... i was changing one of the radiator hoses and my watch caught that line and pulled it out and now i have no clue where it goes....
Follow the hose back to its source. Youll see 2 phillip head screws. Take those off and get a map sensor and put it there.
Re: where does this vacuum line go to? (RACEPAK)
damn and I just sold a d16z6 throttle body with map sensor for 10 bucks, well since your car is a 93 sol is the map sensor on the firewall and that guy had a Z6 swap cause I'm not too sure they made sohc SI's in 93, o thikn they started in 94
Re: where does this vacuum line go to? (GreyDel)
It goes to the map sensor on the firewall. It will be black and it will say MAP sensor on it. Most likely it's a Densio (sp?) stock map sensor. Check beside the fuel filter (to the right of the fuel filter). You will see it so just keep looking on the firewall.
97grnrs
12-31-2005 05:50 PM
