is it possible to replace this stud?
Re: is it possible to replace this stud? (RACEPAK)
yes its easy..just thread 2 bolts on the stud then take it off using the lower bolt to loosen it...
You put two nuts on the post, but only losening the lower one its going to wedge itself against the upper one allowing you to remove the stud like you had the wrench on it.
Mr. Badwrench
Re: is it possible to replace this stud? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">You put two nuts on the post, but only losening the lower one its going to wedge itself against the upper one allowing you to remove the stud like you had the wrench on it.</TD></TR></TABLE>
or find someone with a stud extractor.
http://buy1.snapon.com/catalog...talog
Is there a specific order in which you remove the bolts from the fork and control arms so you dont m
streetracerof06
Suspension & Brakes
05-08-2006 01:16 PM
CrazyKoreanCrx
04-18-2004 06:10 PM
