help! code 10, ECT sensor causing vtec to not work??
Old Oct 5, 2005 | 12:11 PM
ek-to-tha-max's Avatar
Default help! code 10, ECT sensor causing vtec to not work??
i just recently installed a skunk2 manifold on my 94 gsr motor. i have a 97 ek.
since i installed this, my vtec stopped working. i checked my CELS and i got 6,10, 54.
6- IAT (intake air temp)
10- ECT (engine coolant temp)
54- CFK (crank flunkuation)
i know its not 6 and 54 because it doesnt effect vtec. i checked my ECT and its the right plug and everything. could it be my ECT? how do i fix this? my temp on my guage cluster still works so i dont know if it has anything to do with it but yeah can anyone help? any suggestions? thanks.
Old Oct 5, 2005 | 02:07 PM
Caveman74's Avatar
Default Re: help! code 10, ECT sensor causing vtec to not work?? (ek-to-tha-max)
VTEC has to be at a certain temp to engage. If you dont replce the ECT, your car will have a hard time starting when hot. There like 30 bucks at NAPA. I had to replace mine. That is probably your problem.
Old Oct 5, 2005 | 05:02 PM
Default Re: help! code 10, ECT sensor causing vtec to not work?? (Caveman74)
so even tho my temp on my guage cluster works i still need to replace it? how could it just go bad after changing manifolds?
Old Oct 5, 2005 | 07:47 PM
anyone!!?!?!?!
Old Oct 5, 2005 | 07:53 PM
HondaTechPro's Avatar
Default Re: (ek-to-tha-max)
I would check to make sure it is installed correctly. Look for pinched wires, or loose connections, or air in the cooling system somewhere. The temp gauge runs off a coolant temp SENDER.... simple thermistor, and the ECM (vtec) uses the coolant temp SENSOR.... they are different.
Old Oct 6, 2005 | 09:18 AM
Default Re: (HondaTechPro)
ok so where are these sensors? if im right theres one below the dizzy that looks like a nipple and the other one you just have to follow the bottom radiator hose and its a circle plug. let me know
Old Oct 6, 2005 | 03:16 PM
The one below the "dizzy" is the temp sender - that controls the gauge. The other one is the sensor.
Old Oct 6, 2005 | 03:27 PM
Caveman74's Avatar
ECT Sensor is on the left side of the head right in front
Old Oct 6, 2005 | 05:57 PM
switched the ECT sensor about 10min ago, wasnt the problem. any suggestions
Old Oct 7, 2005 | 12:00 AM
caveman, can you explain exactly which ECT sensor you replaced? there are two. which one was it?
92lx
Nov 10, 2012 11:55 AM
LsVtakYO
Dec 5, 2005 10:54 AM
mikebranson
Apr 13, 2004 09:00 PM
jonas
Mar 15, 2003 03:09 PM
The Real Funk
Feb 12, 2003 07:18 PM
