Air/Fuel Gauge giving a CEL
Old Oct 4, 2005 | 07:46 PM
brockscivic's Avatar
Default Air/Fuel Gauge giving a CEL
Ok, ever since i installed my Autometer AF gauge Ive had this weird CEL. IT started about 3 weeks after installing it. It would come on after driving the car 25-20 mins and would say code 1. If you turned the car off and back on it would not show the CEL until you drove it for a few minutes. Would having the AF gauge tied into the harness at the ECU give a CEL? Or is my oxygen sensor on its way out?
Old Oct 4, 2005 | 07:57 PM
Hatch It's Avatar
Default Re: Air/Fuel Gauge giving a CEL (brockscivic)
Hmmm the gauge shouldnt give you a CEL, maybe the way you wired it? Uninstall the gauge and see if it happens. If it goes away there is something wrong with your instilation if not it could be just a coincidence.
good luck
Old Oct 4, 2005 | 08:01 PM
LShatchie's Avatar
Default Re: Air/Fuel Gauge giving a CEL (Hatch It)
yeah when I installed my autometer a/f gauge I was getting a CEL and it ended up I had the wiring wrong
Old Oct 4, 2005 | 08:04 PM
Default Re: Air/Fuel Gauge giving a CEL (LShatchie)
i know its wired into the right wire (the white signal wire...i cant remember the slot) but as far as connections...i think i screwed up using the crimp connectors instead of soldering it.
Old Oct 4, 2005 | 08:26 PM
Hatch It's Avatar
wait you just have a 92 LX?
You hsould only have a wire for power, a ground and the last one thats the signal, which you can run through the firewall and splice right into the 02 sensor on the header....
well good luck
Old Oct 5, 2005 | 04:06 AM
LShatchie's Avatar
does the gauge work properly?
Old Oct 5, 2005 | 10:32 AM
SRCivic97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">does the gauge work properly? </TD></TR></TABLE>
It's a dancing light show unless you go wide band so that question should read..
"Do the lights dance?"
Old Oct 5, 2005 | 10:47 AM
tr0n9h's Avatar
can wrong wirring affect the car performance, cuz mine wire wrong at the moment and its show the cel also
Bbasso
Mar 17, 2005 02:06 PM
troubledsol03
Oct 1, 2004 09:20 AM
g2_boosted
12
Jul 18, 2004 08:10 AM
phazeshifter
Nov 5, 2002 06:09 AM
metal-x
Jul 24, 2002 02:25 PM
