throwing cel codes 4,8,9
im throwin cell codes 4,8,9.. codes are 4 CKP - crank position sensor
8 TDC - top dead center sensor 9 CYP - cylinder sensor ... car is 97ek with type r block,b16 head, obd-1 jumper harness with chipped p28 ecu.. engine light came on after racing on the highway and i redlined 4th.. anyone know what could b wrong?
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (97JDMEKSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97JDMEKSLEEPER »</TD></TR><TR><TD CLASS="quote">no...ive had the swap done for awhile...this just happined outta the blue... could it be my distributor getting ready to go?</TD></TR></TABLE>For all 3 of those codes to appear at once it makes me think a connection came loose. Check that first but if its not in the wiring dist. is bad. Very slim chance it could be the ECU but doubtful.
Re: (HondaFanatic708)
had the same exact thing happen a week ago, this is what you do, go down to auto zone and order the 311.92 dollar distributer with the lifetime on it. you want the dohc 95 del sol vtec, the one where the mounting bolts make the triangle that points up.
bright side is you get a 75 dollar core back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si »</TD></TR><TR><TD CLASS="quote">had the same exact thing happen a week ago, this is what you do, go down to auto zone and order the 311.92 dollar distributer with the lifetime on it. you want the dohc 95 del sol vtec, the one where the mounting bolts make the triangle that points up.
</TD></TR></TABLE> did this fix ur problem?
