Question about EG headlamp
My bulb went out the other day and i tried to change the bulb in the headlight. I havent changed it before because the car belonged to my brother before i had it. When i was taking out the bulb to change it, one of the wire was kind of corroded and i accidently pulled on it and it came out of the clip that holds the bulb, and there's no way i can solder it back on, so should i just get a new harness and resolder the wires together? and could i just get any 9003 bulb harness to resolder it back on?
Re: Question about EG headlamp (Mugen1320)
just get the heavy duty clips that the bulb plugs into. then splice the new wires togther. after this the lights should work and you can also run hotter (brighter) bulbs!
