little green and yellow cluster plugs?
are they the same as integra's
i plan to put a gsr cluster in my car (95 ex coupe) just wondering if i need the integra ones, or if im safe using the civic ones.
Re: little green and yellow cluster plugs? (spooncivic1)
Green plug is for cruise control. Integras have the cruise control wire (red/blue) already integrated into the cluster harness. You will need to cut the wire from the Civic plug and splice a pin to it and stick it in the right slot on the cluster plug. For the SRS, the yellow and blue wires are switched and you will need to swap those around.
so i just cut my cruise plug and splice it into the integra cluster plug? assuming that the wire is already on the integra plug
and for the SRS, will my civic plug into the gsr cluster? (just switch the wires)?
Re: (spooncivic1)
You will Integra plugs though and youll have to splice the plugs into the Civic harness. On the Integra plug, there's already a cruise control wire. You will cut off the Civic cruise control wire from the green plug and splice it to the cruise control wire on the Integra plug. The Civic SRS plug fits the Integra harness, but the two of the wires are switched.
TreyA
09-10-2013 07:00 PM
garrettrauch
07-12-2011 09:29 PM
BlueIntegraBoy
11-28-2004 06:51 PM
