Code 65 again.. ahh..
how do i tell if they secondary o2 heater sensor is going bad? it keeps throwing this code.. ive posted about this before.. and it still wont go away blah.. i bought a new one too and put it on it still threw the code..
its stock cat.. i tried resetin the ecu by pullin the battery cable.. and i wait for like 20 seconds.. put the battery cables back on and the ecu doesnt reset. throws same code. 65
Re: Code 65 again.. ahh.. (pinoyboiwonder)
Get a Helms.
Get a meter.
Measure the O2 heater resistance (as the Helms manual instructs one to do).
Spec is 15-40 ohms.
If it's out of spec, replace it. If it's in spec, follow the Helms troubleshooting outline for futher investigation. There aren't but 3 parts to this 'system': The O2 sensor itself, the wiring harness and the ECU. It's gonna get spendy replacing the other two vs troubleshooting correctly - your call.
Get a meter.
Spec is 15-40 ohms.
Re: (pinoyboiwonder)
I don't know. I generally fix what is broke on my car. I've found that leaving a problem go un-fixed only causes bigger problems down the road.
importnoodles
03-29-2008 10:20 AM
