password jdm intake on a '00 civic ex?
i've searched and really cant find much..
i finally got the password:jdm cf intake, and i've been searching since i bought it but havent found much info on it.
there is one tube going into the stock intake from the valve cover, there is the sensor plugged into the stock intake, and there is another metal tube (that later goes into a tube) that plugs into the stock intake.
the password intake only has a hole for the sensor and the vc tube. i dont want to drill another hole, so how do i go about being able to plug in that last metal tube?
i'm going to assume that i'll most likely have to buy some sort of y-connector to plug in that metal tube with the vc tube.
i was going to replace the metal tube with a rubber one and run it to the intake and then place a breather filter on the vc but i've read around a bit and that doesnt sound like too good of an idea..
intakes going on a stock ' 00 d16y8.. any help would be appreciated
Re: password jdm intake on a '00 civic ex? (dwnthehatch)
to my understanding.. the password jdm comes w/ two holes.
the 96-98 sohc ex stock intake has two holes, but the 99-00 ex stock intake has three.
Re: password jdm intake on a '00 civic ex? (hkt03)
mine came with 2 holes. both of which were plugged obvisously..i swapped out my sensor off my old intake and put it on the new one..the tube i ran from the intake to the breather on the motor
i have had no problems. no cel and it sounds nice
i can try to get some pics tomorrow if you need them
Re: password jdm intake on a '00 civic ex? (00CivicGirl)
i've had mine it on for a few days now, but runnin' it using a breather filter while i figure out some way to use a y-connector to run both hoses into the intake.
but if you can, a pic or two would be great, thanks.
darkknightwong
03-16-2002 04:31 AM
