Civic Sir axle vs Integra axle
Old 04-05-2006, 11:48 AM
wildman117's Avatar
Default Civic Sir axle vs Integra axle
I have a honda civic sir. My passanger side axle is clicking. Piston ring offers lifetime warrenty on axles, but they don't have a listing for the Sir. They only have the civic Si and base models. Is there another shaft from a honda that is more common which I could use in their computer to get the right shaft?
Old 04-05-2006, 01:25 PM
sol lovin's Avatar
Default Re: Civic Sir axle vs Integra axle (wildman117)
sir is that dual cam stock? if it is, any bseries axles will work depending what year it is. if its single get single cam axles for your year.
for example you have a 92-00 civic with a b16 swap you use b-series axles from a 94-up integ, 99-00 si civic
if you have an ef it might be different with the DAs too.
Old 04-05-2006, 01:54 PM
wildman117's Avatar
The car came stock with a b16. Piston ring has different part numbers for GSR axles and other integra axles. Which is the right one to use?
Old 04-05-2006, 03:31 PM
egsleepercivic's Avatar
only difference between 94-up B series axles is abs or no abs. if you don't have abs you can get either. if you have abs you have to get abs axles. oh JDM r's and CRV's have 36mm axles while all others are 32mm. hope this helps good luck. are you in canada?
Old 04-05-2006, 08:33 PM
wildman117's Avatar
yea I am from canada
DC206R
03-27-2011 06:55 AM
aojtin
04-16-2009 05:20 PM
bratch
10-06-2008 10:56 AM
slow_db7
04-11-2008 12:37 AM
ncrx1
12-13-2001 05:52 PM
Quick Reply: Civic Sir axle vs Integra axle
