96+ civic front sway bar difference
hello everyone,
i have 97 civic hatch that didnt came with a front and rear sway bar.
i installed a rear sway bar and the car is alot stiffer in corners and it bearly leans to the sides.
now.today i got a front sway bar from a 98 4dr. and my front lca's dont have the brackets on them for it.
should i get different lca's? is it worth the trouble and money?
thanks,
thanks,
Re: 96+ civic front sway bar difference (RACEPAK)
i put a front sway bar off a 98 ex on my 96 cx. i noticed a pretty big difference in corner handling. the front lca's arent that expensive. do it.
Yes, you'll notice a difference. I ran just a rear sway for a few months until I gotten ahold of a front sway.
You can use front LCAs from a 92-00 Civic EX or 94-01 Integra. To make installation easier, just swap the portion with the hole and the bushing, not the part connected to the lower balljoint of the knuckle.
Re: 96+ civic front sway bar difference (BlueIntegraBoy)
thanks everyone.
i didnt had the chance looking under the car. does my chasis comes with taped holes for the bushing bolts?
Yes it comes pre-tapped with the holes for the d-brackets. I installed a 96-00 Civic EX front 22mm swaybar on my 99 hatchback and it made a difference. Yes it does induce more understeer, but you get less body roll in the corners. All you need are 96-00 Civic Ex front LCA's.
Re: 96+ civic front sway bar difference (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Don't you need the Si front shock forks? </TD></TR></TABLE>
Only if upgrading to the 26mm Si/CTR front sway bar with Si/CTR front LCAs.
dont forget.. with SI/CTR sway bar upgrade u cannot run traction bar.. w. the EX/HX/LX lca's u can run both sway bar and traction bar
my knowledge the only difference is.. that the stock EX has smaller diameter of swaybar then SI/ctr.. but u can buy aftermarket sway bar for ex/hx/lx lca's that is bigger then si/ctr sway bar
Re: (JimDCXC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimDCXC »</TD></TR><TR><TD CLASS="quote">bigger isn't always necessarily better though</TD></TR></TABLE>
struggling with that right now, got a 96 hatch 22mm rear cant decide on front, cars used for roadracing and only runs rr slicks (nitto nto1's).. 22 or 26 that is the question...
b20hatchek
Suspension & Brakes
10-18-2010 04:19 PM
