turbo help
turbo help
ok guys i got a t25 i droped ni my d16z6 in my del sol ever thing is hooked up and for some reason ino boost is gettin to my engine i dont know if its because i have all my vaccum line spliced into one line and it has vaccum but i got no boost reaching the engine
Man U FTW
this is a good one for the FI section....
is your wastegate stuck, is the BOV stuck open, are all of your vaccuum lines hooked up correctly, are all of the couplers tight??
Those are a few things you could check...
Re: (h22delsol)
What did you use for charge pipes? A kit or did you do it yourself?
Any chance of bad welds/couplers with holes in them?
If everything is off of the same vacuum source there is a possibility that your BOV is not closing when you go WOT because the vacuum source may not be strong enough to close it.
Re: (Everyones Hero)
I'd check to see if your charge pipes actually lead from the compressor outlet to the throttle body 1st. OR that you have them for that matter. Forgive me if you actually have theses, theres is just always that one 'special' guy each month that slaps a snail on - naked - clueless how it works & makes power.
Sounds like a severe leak otherwise, your vac gauge should be connected after the throttle body.
