obd2 gsr to obd1
obd2 gsr to obd1
i have a 97 civic hb cx that i will be putting in a obd2 b18c1 and i want to make it in to an obd1. i no that i need a under dash wiring harness for the ecu, but what modifications do i need to do to the engine harness?
and if i use a 96 ex engine harness will it work in this occasion so i dont have to wire vtec and the other connections needed?
Re: obd2 gsr to obd1 (HB-Civic500)
If your engine and car is OBD II then leave it that way. Don't change the OBD type. Otherwise you have a wiring nightmare.
Re: obd2 gsr to obd1 (EG6LS)
sionce its a ek, run everything 0bd-2 then at the ecu get a jumper harness and run a obd1 ecu. that will save you time and a headache
jdmshawn95
01-14-2011 11:12 AM
danxdan
06-09-2005 04:46 PM
