Car idles but bogs and dies????....
so i have a 93' civic dx and i just took of my turbo kit... i removed the dsm 450's and put in the stock injectors. i also removed the safc witch i was using to get it to run. so it is wired exactly like factory but i'm haveing some problems,
The ignition feels like it is just cutting out. i couldn't get it to start and it was thowing a injector code and i new the injectors were good so i swapped computers... well it started but it did want to idle... well after 5-7 min of holding around 1000-1500 rmp it would idle but it kinda had a lil rev to it like a bad iacv.. so i tryed to drive it to the parking spot from the garage and it just wanted to bog anything over part thottle and it wouldn't go past 3000-3500 rpm... also it was throwing a solid cel. hrm..
well i went back to it after taking a break... and now it will only idle for like 5 sec then bog out... and if i try to give it gas it just dies... im so confused at this point? any help would be apreciated??
thanks matt
thanks matt
Re: Car idles but bogs and dies????.... (91jdmhatchback)
Have you pulled your plugs to see what they look like? I kinda had the same problem when I forgot to tighten my valve cover and oil was leaking into the cylinders. Had a solid cell and all, most likely thats not your problem but its a start.
all the wires for the sensors pluged in where they are suppose to be ? maybe got something mixed up
Re: Car idles but bogs and dies????.... (john666)
i never touched any sensors... and i just replaced the plugs with new ones.. so i'm lost.. i'm going to do a compression test this week and see if the motor isn't toast...
Topdawgg
06-28-2006 01:03 AM
racinskittle
01-18-2004 07:06 PM
