"97 Honda Civic parking brake problem - Help appreciated
Old 10-29-2006, 07:34 AM
Kennydee's Avatar
Default "97 Honda Civic parking brake problem - Help appreciated
Hoping someone can help...
Every time it gets cold (freezing) and when the parking brake (hand brake) is applied, the rear wheel or brake cable on the passenger side jams. I'd like to disassemble the hand brake cable and either replace it or manage to grease it or something and/or inspect and determine what is causing this. Could someone please provide a link to schematics of the cable assembly at the rear wheel level where the hand brake cable attaches. A method for replacing the hand brake cable would be appreciated as well.
Many thanks
Old 10-29-2006, 07:41 AM
old man neri's Avatar
Default Re: "97 Honda Civic parking brake problem - Help appreciated (Kennydee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kennydee &raquo;</TD></TR><TR><TD CLASS="quote">Hoping someone can help...
Many thanks</TD></TR></TABLE>
This is normal, a lot and a lot of cars do this. This is why it is not recommended you don't use your parking break in the winter unless you absolutely must. It might not even be your cable but the actual shoes themselves freezing on. You can try to replace the cables and put all the grease you want but chances are it will happen again at some point. Hope this helps.
Cheers.
Old 10-29-2006, 07:49 AM
Kennydee's Avatar
Default Re: "97 Honda Civic parking brake problem - Help appreciated (old man neri)
Many thanks for your reply. Makes sense that the shoes are jamming and not the cable because the lever inside the car feels as there is no cable attached; no pull. The rear passenger wheel is the only one jamming though. Would you happen to know if there are any blow out diagrams of the rear wheel brake assembly available?
Many thanks again.
Old 10-29-2006, 08:09 AM
Old 10-29-2006, 08:22 AM
Kennydee's Avatar
You are amazing Old Man Neri!!! This online community is fantastic.
Thank you so much. We really appreciate your help.
Have a great day.
Jakester9500
11-03-2016 08:12 AM
flyinfree
09-09-2011 08:55 AM
GWInquisitor14
08-16-2011 05:38 PM
kustom_2323
09-30-2009 02:02 PM
cinci27
09-09-2007 08:41 AM
Quick Reply: "97 Honda Civic parking brake problem - Help appreciated
