HELLA HORN INSTALLATION ON 92-95 CIVIC EG H/B...
I got a hella horn kit from my work off a used car at benz(dual horn w/compressor) ...and was wiring it up and i would connect the wire for the signal from the horn to the steering wheel and it would keep the horn on??...i was told since the kit is for a positive based wire and hondas are negitive(signal from the horn)that i would have to send constant positive power throught the ground instead of grounding it.......HELP!!!ANYBODY
honda horns do use a switched ground to turn on the horn.
to use the same signal on a positive switched system simply use a relay to switch the signal polarity.
85 - switched signal from steering wheel
86 - constant power
30 - constant power
87 - 12V switched output
86 - constant power
30 - constant power
Re: (Relic1)
I Installed the horn system and when i try to tap in to the signal for the horn to the steering wheel and the horn would stay on(tapping in at where the horn button and connector are behind bumper)...?????
BolivianFuego
17
07-18-2013 01:27 PM
