Failed NJ emissions help
I went for my test today and revved my car to redline twice on the way
I failed N0x & C0:
N0x 3412/1372 failed
HC 151/ 173 passed
C0 1.14 / .97 failed
C02 12.2
02 1.9
did a little research:
https://honda-tech.com/zerothread?id=1827227
the reasons for each seems to contradict
knowing i purposely revved is that my problem?
i rememeber reading it needs to be done for a cat temp test
since HC is fine, then my cat is good?
for next time:
oil change
top off collant
drive normally
i have i/h/e and high flow cat (al ebay crap)
and i run 93 octane cause it helps my idle
that should help with my temp and will hopefully fix each reading
can anyone add any more help/info?
I failed N0x & C0:
HC 151/ 173 passed
C02 12.2
02 1.9
for next time:
oil change
top off collant
drive normally
Re: Failed NJ emissions help (sicones)
i just read that'll hlep but it didnt sound like it would A LOt
ill of course do it anyway, thanks
those scores have to do with my engine and NOT my cat, right?
1 Post
Re: Failed NJ emissions help (dafuzzbudd)
CAT.
Reason why I say this is all your numbers are up. And your O2 that is left over is very high. That is unless you have an exhaust leak.
It is not the motor.
When you replace the cat I would replace the O2 sensor also.
Your numbers should be like this...
Nox under 300
CO very close to 0.0
HC 30 - 90
O2 0.0 or close to it
Co2 Doesn't matter but around 15.0
And run 87 octane... it matters.
Nox under 300
HC 30 - 90
Re: Failed NJ emissions help (thesmogman)
i do have an exhaust leak,
i have a crack in my header
will be jbweld'ed soon as i can not use it for about 12 hours
should i get something like this?
http://cgi.ebay.com/ebaymotors...QrdZ1
or
http://www.hondamarketplace.co...38627 but i need flanges
they don't look long enough
Modified by dafuzzbudd at 8:53 PM 12/14/2006
or
anyone know where i can get a real cat with flanges?
how much does anyone think it would cost to get them put on a cat without them?
I don't know much except it's hard to fail a NJ/NY emissions test :-\. You must be OBD-II - OBD-II blows for that reason.
Anyways, only thing I wanted to point out is that you said that you use 93 because it helps your idle.
No it doesn't. You think it helps your idle while on your stock engine it does absolutely nothing than plain 87 octane would do. Also, the car is made for 87/89 octane, look it up on the book.
Re: (Syndacate)
93 is so cheap it doesnt matter much
i still see mpg and idle argued and i DO notice an idle difference
i would agree "the book" says my car is made for 87
and by the way, my eg is obd1
back to the point of emissions:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">anyone know where i can get a real cat with flanges?
how much does anyone think it would cost to get them put on a cat without them?</TD></TR></TABLE>
Magnaflow direct fit replacement cat: about $69 shipped from http://www.performancepeddler....22636
the only mod you'll have to make is to enlarge the two holes on the spin donut flange so the spring/bolts will pass through. Also the springs are a bit long on the stock ones so I cut off 2 coils and it works good. Also think about getting the 3bolt flange rewelded, mine's leaking a bit because of a bad weld bead.
But usually your local muffler shop can weld in a replacement OBDI cat for like $80 or so dollars.
Re: (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">i am wanting to keep high flow, i have 2.5 piping
80 just welding flanges on a non-install?
i ******* hate shops</TD></TR></TABLE>
The shop my me will install a new cat (not just the labor, but part and labor) on OBDI vehicles for about $80. Basically they cut out your stock one and reuse the flanges. I don't know what brand cat they use, but its gotta be a good cat because I dont think exhaust shops can install a non compliant cat, be it OBDI or OBDII.
Re: (chrisw85)
that link looks like a good deal will it fit my 2.5 piping?
http://www.car-sound.com/02pro...22636
looks like it's 2 inches
if i have a leak and it's too loud ill replace it after i go through testing
Modified by dafuzzbudd at 5:36 PM 12/17/2006
Re: (dafuzzbudd)
situation stil lnot resolved due to uncertainty
i think im going to buy the 2.5 obx one from ebay.. about $150
i have a dc 4-2-1 replica header and 2.5 cat back
i believe the cat will fit my piping fine, but will it not fit the header?
if there is a leak ill switch back i guess after testing
someone please tell me if this'll work
1 Post
Re: (dafuzzbudd)
My stock replacement cat was $86 bucks and $30 to put it on at a muffler shop.
The cat has 2.5" pipe and mates perfectly with my DC421 header.
High flow cats are designed to just barely get you by. So most of the time you are replacing it for every test.
You are not talking about a hugh amount of performance gain so I stick with a stock one.
Your exhaust leak could be some of your problem as the leak is before the O2 sensor.
Re: (thesmogman)
im obd1 so i only have one at the header
i dont want it welded because anything else i do (swap/turbo)
will require a shop visit
ima measure the exact size of the piping to figure out if my header is 2.5
Ek Forever y0!
Re: (dafuzzbudd)
Then give up.
1. All that higher octance is going to do is help keep your engine from knocking.
- Is your engine knocking?
2. There's only been a dozen suggestions in this thread already, try a few of those first, run regular gas, and go get tested again.
3. WTF is with the "High flow cat" of fast spooling?
- I bet you have a D-slammer with 87 hp to the wheels. If I'm wrong that statement is completely retracted and resounded apologetically.
Re: (ek forever guy)
i measured my piping and i do have 2.25 header and 2.5 piping
my fake cat is 2.5 both sides though and it fits my header fine
final question: do you think the 2.5 obx ebay cat will fit fine?
i do think that is my cheapest option
Re: (dafuzzbudd)
a shop by me seemed pretty cool
they said $80 to put flanges on
will i encounter any problems if i give them this cat?
http://cgi.ebay.com/ebaymotors...wItem
im almost done bothering
Re: (dafuzzbudd)
someone please just confirm that there is nothing wrong with choosing this cat
im making sure the circle type one is ohk vs. the oval
teewhy55
11-30-2006 01:10 PM
