93 integra seat, 98 civic coupe
i have searched this for about an hour now and cant find any conclusive answers. what does it take to fit a 93 integra front seat into my ek?
i know its not a direct bolt in, just want to know what im going to need to do when i get my seats in about 2 weeks. thanks
EDIT: i am putting this in here for anyone that actually searches for their information, that they may read this. you cannot just swap rails from a DA teg seat to fit an EK civic. it will require ginding, cutting, welding.
Modified by ridin98civic at 2:22 AM 1/19/2007
If the 93 integra seats are like any of the later model integras or civics, swap the rails. Two bolts on either side of the seat pan, two on the window side of hte seatbacks and one on the inside. You have to pull the foam up a bit to reach the higher bolt on the seatback
basicly just compare seat brackets to each other, i kno one of the integra seats in 96-00 civic u cant jus put 3 bolts in and call it a go. not sure about the 93 teg seats tho
may be same situation or you may have to change the brackets completely just compared and see what u have to do
i put 01 gsr in my 97 civic just did 3 bolt thing, but if ur a short guy im (5'9'') but the teg seats sit alot lower with teg brackets. were the civic seats sit alot higher so if ur not tall u might not like the low feeling. comparing urself to windows and steering wheel after
was just off to me steering wheel always felt to high and all
Re: (MyzO)
yea i figured that would be it, was hoping to find a write-up on exactly what would be required, but i guess im not that lucky. thanks guys. anybody else?
like a year ago i would have known all the details to it, but ive been out of the honda stuff for a while now so ive kinda forgot alot.
dont get me wrong i still drive a honda but i was low on funds so couldnt even think about moding lol give me a few minutes tho ill see if i can pull up any kind of write up on it
bolt in fit (may require swapping one or both rail(s))
Del sol seats
94-01 Integra seats
92-95 Civic seats
CRX seats
S2000 seats
01-05 Civic seats
fit by welding
91-96 Prelude seats
97-01 Prelude seats
02+ RSX seats
so basicly with the 93 integra you'd have to change the rails, if u just pull ur old seat (4bolts) and go to put in the integra seat you'll see exactly what i mean. cause were the rail has to be bolted one of the bolts is bent down like 90 degrees and its in a differant spot from 93 integra to ek civic
so what i would do pull 1 seat out bring it inside if its cold out lol and jus start swapping the rails or pan
Del sol seats
94-01 Integra seats
92-95 Civic seats
CRX seats
S2000 seats
01-05 Civic seats
fit by welding
91-96 Prelude seats
97-01 Prelude seats
02+ RSX seats
for sure someone else will always be looking for the info.
id do write up for you if i had the 2 seats to compare which i did a week ago but recently trashed the teg seats. shitty ripped stain'd tan ones lol
search archives next time.
https://honda-tech.com/zerothread?id=826594
Edit: the pics are down. If you're lucky tomorrow morning ill go out and take some quick pics of the bolts you need to remove. Its such an easy task you'd never believe it. Takes about 15 minutes when you know what you're doing.
https://honda-tech.com/zerothread?id=1436635
http://www.splitimageracing.co...8.705
Maybe those will help.
Modified by ek gripper at 3:06 AM 12/14/2006
jdmmotors
01-14-2007 11:54 AM
