What's Causing this Engine Noise???
Old 12-14-2006, 05:16 PM
cleartouch33's Avatar
Default What's Causing this Engine Noise???
view video clip her
http://www.youtube.com/watch?v=35w4jZAcaFM
Old 12-14-2006, 05:17 PM
I Shot 50 Cent's Avatar
Thats weird...
UP for some good answers. I'm just as curious as you are. You mean like...the sputtering type sounds a few seconds into the clip, correct?
Old 12-14-2006, 05:40 PM
Default Re: (I Shot 50 Cent)
yes, the clicking. it clicks in increments of 5 times and the motor vibrates when it clicks each time. not sure why???
Old 12-14-2006, 05:49 PM
LSVTECEG757's Avatar
you might need a valve adjustment
Old 12-14-2006, 05:53 PM
Midori Green's Avatar
Default Re: (LSVTECEG757)
Wow you got me on this one. Hopefully a Honda Tech sees this thread and can help you out. Do you do any maintenance on the engine.
Old 12-14-2006, 05:54 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECEG757 &raquo;</TD></TR><TR><TD CLASS="quote">you might need a valve adjustment</TD></TR></TABLE>
he definitely needs a valve adjustment. but the knocking in increments is weird. i've had some pretty loud tapping valves, but never knocking.
get an adjustment done and see what happens.
Old 12-14-2006, 05:59 PM
Default Re: (philosofy1)
whats weird is when this clicking noise takes place, if i turn off the a/c, then it stops. if i keep the a/c off then it goes away. not sure if there is a direct connection??
Old 12-14-2006, 06:10 PM
philosofy1's Avatar
Default Re: (cleartouch33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleartouch33 &raquo;</TD></TR><TR><TD CLASS="quote">whats weird is when this clicking noise takes place, if i turn off the a/c, then it stops. if i keep the a/c off then it goes away. not sure if there is a direct connection??</TD></TR></TABLE>
when you say click you mean the increments, right? are you sure it's coming from the motor. you sure it's not the a/c compressor.
Old 12-14-2006, 06:33 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
when you say click you mean the increments, right? are you sure it's coming from the motor. you sure it's not the a/c compressor.</TD></TR></TABLE>
I second that.
Find out where it's coming from, block, head, whatever. It might be an accessory like the AC comp.
Also, check the timing :-\.
EDIT:
Other possibilities (but not what I'd look into first) are fuel injectors and/or rotor/cap/plugs/wires.
Old 12-15-2006, 09:18 AM
Default Re: (Syndacate)
i think you guys are right about it being the a/c compressor. i didn't think of that until i figured the clicking stops when a/c is off. i will double check and get back to you guys. thanks for helping out. you guys are very helpful.
Jay
ph0shizzle
08-09-2006 04:38 PM
frank2660
05-07-2006 06:17 PM
ej2civic
10-02-2005 09:43 AM
bananacruzier
02-16-2002 10:06 AM
BryanS
09-25-2001 10:46 AM
Quick Reply: What's Causing this Engine Noise???
