valve clearance?
valve clearance?
i have a '99 Si motor and i installed ITR cams...what should be the proper valve clearance for these cams? is it the same as factory?
Re: valve clearance? (jdmETi)
if I were you, I would go with the type r valve clearance
intake 0.15-0.19mm (0.006-0.007) inch
exhaust 0.17-0.21mm (0.007-0.008) inch
anyway I checked and the valve clearance on the type r, gsr, and si are all the same
