Wheel Stud Replacement
I recently noticed a horrible shake in my car, so I get out, look at all the wheels and my front drivers side wheel only had 2 lug nuts on I checked and 2 of the studs had broken right of. Not sure how it happened
Tomorrow Im going over to NAPA to get two more then put them in.
Will I need to pull the whole hub assembly? Or can I slide the studs in from behind without mangeling the threads?
TIA!
TIA!
Re: Wheel Stud Replacement (CodyC142)
you will have to pulll the hubs out to put the studs in properly...there is a thread on here on how to do it properly...and also there is another thread to do it with a slide hammer. just search
Re: (Eran)
Ahh.. On my 93 Si its a little different. Ive heard that the stud actually hits the hub on the other side.
Any other input
Any other input
Re: (CodyC142)
for some reason I cant search on honda-tech. It just wont complete it from my house computer. It just spins and spins and spins and spin.
Re: (t0p_sh0tta)
Yes bend the brake shield or like I did snip a lil piece out. If you cant hammer old stud out all the way cut the heads off with a grinder. I still had a tight fit putting new studs in so I used a grinder to make a flat side (Just as much as it takes) which made it possible to clear the blockage. Those Hubs are a pain to remove in my experience (only tried once) so this ghetto method might work for you too.
I have had no problems ever since.
I hate the way Honda makes you take the hub off to change em it's such a Beeoch!!
When all else fails and your broke go Ghetto-tech
Re: (Budget Racer)
I did all the studs on my 93 Si with out removal of the hub assyit wasn't all that hard but I alos had a hot knife to help get the old studs out.
Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">This took me 5 seconds of searching ....
http://www.50mod.com/fourthgenhatch/wheelstud.html</TD></TR></TABLE>
If you do it like this, make sure you weld the stud in the back.
I do all mine like this:
http://www.hondaautomotivepart...INDOW
Re: (Luserkid)
Yup thats how I did it except I barely flatend one side of the stud and it worked great. There was still enough material so that the stud head would stay strong.
Was up Cali
Was up Cali
MadVladCivic
12-03-2015 06:50 AM
calvinchang2003
27
08-23-2003 05:09 PM
