H2B... Is it worth the money?
I'm considering an h2b swap. The main problem I can forsee is the wiring. But all totaled it is going to cost roughly 4k. Are the numbers worth the money, or should i jsut go another route?
Ek Forever y0!
Re: H2B... Is it worth the money? (turboD_EG)
The wiring isn't much differen't at all.
Yes it's worth it.
If you do labor yourself you can easily do an H2b for under $4000.
I think I added it up one time and I got ~$3500.
It's the new cool swap. k20's have something to fear.
Yes it's worth it.
Re: H2B... Is it worth the money? (ek forever guy)
Does anything need to be modified on the harness to work, or is it plug and play in a 95 civic coupe?
Ek Forever y0!
Re: (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">Sorry for my n00b-ness but what is an h2b?</TD></TR></TABLE>
Mating an h22 engine to a b-series transmission via a special adapter plate and mounts.
Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Mating an h22 engine to a b-series transmission via a special adapter plate and mounts.</TD></TR></TABLE>
Thank you
Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboD_EG »</TD></TR><TR><TD CLASS="quote">Does anything need to be modified on the harness to work, or is it plug and play in a 95 civic coupe?</TD></TR></TABLE>
basically you have to extend the alternator wires and run a resistor box depending on what injectors you use
Ek Forever y0!
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Ask the moderator Bense, hes a Hybrid guru, hes currently working on H2d, or F2d, not sure.</TD></TR></TABLE>
it's an f2d.
F series and H series are externally identical. The IM and some of the internal parts are different. For example the crankshaft i believe is different.
it's an f2d.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboD_EG »</TD></TR><TR><TD CLASS="quote">I'm considering an h2b swap. The main problem I can forsee is the wiring. But all totaled it is going to cost roughly 4k. Are the numbers worth the money, or should i jsut go another route?</TD></TR></TABLE>
Wiring is exactly the same as doing a regular H22 swap. You would want to use your Civic harness and pull plugs from the H22 harness to add to the civic harness. There is a thread on HT that gives you step by step instructions.
Swap costs roughly 3-4K, basically drops in like a B series swap, and for the money cant be touched by any other Honda hybrid swap.
Ek Forever y0!
Re: H2B... Is it worth the money? (Alchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alchemist »</TD></TR><TR><TD CLASS="quote">
Swap costs roughly 3-4K, basically drops in like a B series swap, and for the money cant be touched by any other Honda hybrid swap.</TD></TR></TABLE>
Yup, most of the K-series guys are like
They have some competition.
What about the other problems with swapping in the regular H22. The most typical complaint being the engine tilt causes oversteer issues. Is this still a problem with the H2B conversion in an EG, or is this somehow overcome?
Ek Forever y0!
Re: (n.famous.1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n.famous.1 »</TD></TR><TR><TD CLASS="quote">Anybody if the evolution is worth buying over the quartersports version???</TD></TR></TABLE>
6 of one, half-dozen of another.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travelor101 »</TD></TR><TR><TD CLASS="quote">What about the other problems with swapping in the regular H22. The most typical complaint being the engine tilt causes oversteer issues. Is this still a problem with the H2B conversion in an EG, or is this somehow overcome? </TD></TR></TABLE>
No, axle placement is like a regular b-series. So no axle issues like the h22 which had the axles at wonky angles which require beefier axles/differentials.
The handling issues with the h22 is a myth. h2b's weigh roughly 20lbs more than a b-series and sit directly over the axles. It's the same whether your h2b or regular h22 swap.
I've heard these swaps are pretty sick. Their 1/4 mile times are very impressive for little modification. How are you going to be using the car. Daily?Weekend? Here https://honda-tech.com/zerothread/2006239
(c-speedracing should make a "how-to" on this swap. There getting more and more popular. )
Ek Forever y0!
Re: (Boost_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V »</TD></TR><TR><TD CLASS="quote">(c-speedracing should make a "how-to" on this swap. There getting more and more popular. )</TD></TR></TABLE>
That's because h2b swaps my k20 owners buttholes pucker.
