it only helps if people see it
https://honda-tech.com/zerothread?id=1976164
help me!
i found this post and didnt understand it
https://honda-tech.com/zerothread?id=1961077
this part: "The problem is in the amp or the signal to the amp, try this, reconnect the sub, unplug the RCAs at the HU or at the amp and plug in another set, hold one of the RCA leads in your hand so that you can use your thumb to "short" the the RCAs signal center pin and the RCAs outer signal return sleeve, listen at the sub and touch your thumb, [on and off on and off] to the RCA, if you hear nothing at all from the sub the amp is the problem, on the other hand if you hear a "hum" the problem is the HU or the RCAs.
If for any reason ground is "lost" from amp when its on and turned up even a little, the amp will get it's ground through the signal return and the signal return trace on the circuit board in the HU will blow like a fuse, check amp ground and plug RCAs into another set of RCA outputs if the HU has any, and try it. 94"
translate please!
Modified by neli_nael at 10:37 AM 5/7/2007
help me!
translate please!
Ek Forever y0!
Re: it only helps if people see it (neli_nael)
Try the audio/security forum. It moves pretty fast and more people in there know more about sound sustems and audio equipment.
Reported.
Reported.
Re: it only helps if people see it (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Try the audio/security forum. It moves pretty fast and more people in there know more about sound sustems and audio equipment.
Reported.</TD></TR></TABLE>
yea i have it posted there but i dont think anyone is in there
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neli_nael »</TD></TR><TR><TD CLASS="quote">
yea i have it posted there but i dont think anyone is in there</TD></TR></TABLE>
(A lot of people are asleep)
Maybe it's just me, but wouldn't it make sense to remove the cap?
Check the charging system for piece of mind afterwards.
Re: it only helps if people see it (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Maybe it's just me, but wouldn't it make sense to remove the cap?
Check the charging system for piece of mind afterwards.</TD></TR></TABLE>
what cap do you mean, capitalization in my post or the capacitor?
Feuerraeder
Audio / Security / Video
12-24-2002 09:06 AM
