troubles
troubles
in the way of building my turbo kit i knew i would have little problems so heres ny question this morning i got up to open my shop upholstery shop and when i was shifting gears i noticed that my clutch was really easy to push dow i was wondering is this A sign of my clutch going out
Re: troubles (lsturboswap)
Could be your clutch master cylinder. Check if its leaking anything, look at the shart to see if brake fluid is on it. If so, replace it and that my take car of your problem. Also, make sure your fluid is full. You could try bleeding the system.
