Cd player
Cd player
Hi i drive a 99 honda civic and when i put in a cd i get this error it says cd e-00 look at. No i dont think just a stock civic radio from 99.
Modified by deerman2701 at 5:34 PM 5/7/2007
Ek Forever y0!
Re: Cd player (94Hatchd15b7)
Reset your CD player.
Pull the fuse for 30 seconds or unplug your negative battery terminal for 10 seconds.
It will clear it's memory and hopefully that error code.
be professional
Re: Cd player (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Reset your CD player.
It will clear it's memory and hopefully that error code.</TD></TR></TABLE>
Keep in mind that you're going to need to enter the 5-digit security code if you do this.
Ek Forever y0!
Re: Cd player (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Keep in mind that you're going to need to enter the 5-digit security code if you do this.</TD></TR></TABLE>
Even on a factory civic stereo?
Ek Forever y0!
Re: Cd player (deerman2701)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deerman2701 »</TD></TR><TR><TD CLASS="quote">Nope no cd in it it gives me that error when i put a vd in then it ejects it then it takes it back.</TD></TR></TABLE>
Did you try disconnecting the negative battery terminal?
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Even on a factory civic stereo?</TD></TR></TABLE>
You don't need a code for the '96-'98 Civic CD players, but you do for the '99-'00 CD players.
Here's a list of error codes for a '98... but I don't have it for the '99-'00. Your owner's manual in your glovebox should list them too.
Re: Cd player (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
Weird i get a error Cd E-00
Re: Cd player (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">either way its broke. fix it or replace it.</TD></TR></TABLE>
I knew that or else i wouldnt be posting...I need to know how to fix it stop posting useless stuff man.
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deerman2701 »</TD></TR><TR><TD CLASS="quote">Weird i get a error Cd E-00</TD></TR></TABLE>
That's why I said to check your own owner's manual.
I knew that or else i wouldnt be posting...I need to know how to fix it stop posting useless stuff man.</TD></TR></TABLE>how is that useless, unless your a repair tech that fixes radios and you have a supply of replacement parts you cant fix it. you can send it to http://www.unitedradio.com like the dealer would prolly do, or buy an aftermarket. you can post here all you want, it has to come out and be sent for service or replaced. i think its stupid as **** honda even gives those damn cd errors. when technically everyone of them come from the pickup assembly(laser) or splindle motor being bad or the cd mech. being jambed. and please do not use one of those laser cleaning discs, all they do is make things worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">how is that useless, unless your a repair tech that fixes radios and you have a supply of replacement parts you cant fix it. you can send it to http://www.unitedradio.com like the dealer would prolly do, or buy an aftermarket. you can post here all you want, it has to come out and be sent for service or replaced. i think its stupid as **** honda even gives those damn cd errors. when technically everyone of them come from the pickup assembly(laser) or splindle motor being bad or the cd mech. being jambed. and please do not use one of those laser cleaning discs, all they do is make things worse.</TD></TR></TABLE>
Thank you and well put. That equipment is all I use to work on. When we got a unit like that 90% of the time we sent it to unitedradio due to a lack of part support. OP it sucks but this is the truth somethings you just can't field service even if you think you can
EnriqueDovis
13
09-26-2004 04:01 PM
yeaaaa its slow
Audio / Security / Video
02-16-2003 02:44 PM
