Does a p30 ac bracket fit a jdm gsr block?
I know they are lots of results if you search, but their is not a direct answer everything is a "IF", So can someone shed some light on this Ac stuff and maybe make it a sticky thanks
Re: Does a p30 ac bracket fit a jdm gsr block? (BoRiCuA)
im pretty sure the p72, p73, p30 and p54 brackets will all fit.
use the p30 or p54 is ur gonna keep ur civic ac compressor.
Re: Does a p30 ac bracket fit a jdm gsr block? (Downey)
so if i get the p30 bracket it will bolt up to the gsr block, and i can use the civic ac compressor?
#1 Super Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey »</TD></TR><TR><TD CLASS="quote">
use the p30 or p54 is ur gonna keep ur civic ac compressor.</TD></TR></TABLE>
I think you mean p54 (del-sol VTEC) or p7j (96-00 CRV) for a civic compressor on a B-series motor. I know for a fact that p7j fits the civic compressor since I have one on my civic w/ B18c swap right now...
What car is the P30 engine bracket out of?
Re: Does a p30 ac bracket fit a jdm gsr block? (dek1mfk)
Well if the p30 works on my b18c block with my civic ac compressor i'll buy it, can someone please confirm or unconfirm this please!![QUOTE=94eg!]
Does the crv bracket have the torque mount also? I would like the reinforcement up front
Re: Does a p30 ac bracket fit a jdm gsr block? (94eg!)
If i use the p30 bracket which comes out of the 99-00 civic i believe b16a2, can i use the single cam ac compressor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoRiCuA »</TD></TR><TR><TD CLASS="quote">If i use the p30 bracket which comes out of the 99-00 civic i believe b16a2, can i use the single cam ac compressor?</TD></TR></TABLE>
no P30 is for Bseries compressors only you will need a P54 or P7J if you are going to use a D series AC compressor......I would order one fromt he dealer since they are a little harder to find....
#1 Super Guy
Re: Does a p30 ac bracket fit a jdm gsr block? (RedZone)
Comparing these two compressors it is obvious you cannot mount one on the others bracket. The bolt holes are in different locations. As RedZone stated, you will need the P54 or P7J mount bracket to make it work...
94 Civic CX:
99 Civic Si:
94 Civic CX:
99 Civic Si:
kenji
15
12-03-2002 02:28 AM
