// How can I remove this ???
So today i finally took off that stupid front plate my car had. I was wundering how would i go about removing those holes that are left on the bumper.
I live in florida so i dont need the front plate but those nostrils on the bumpers are looking ugly. Any sugestions would be great. Thanks
Re: // How can I remove this ??? (Grip-1EM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip-1EM »</TD></TR><TR><TD CLASS="quote">Any sugestions would be great. Thanks </TD></TR></TABLE>
Talk to a dealer or find some H-T members who are selling plugs
they look like this
they look like this
is this a trick question.. you can't take off those holes. you can however cover it up with those oem license plate caps or bondo it and smooth it out.
Re: (airmax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airmax »</TD></TR><TR><TD CLASS="quote">is this a trick question.. you can't take off those holes. you can however cover it up with those oem license plate caps or bondo it and smooth it out.</TD></TR></TABLE>yes you can, just do what archidictus said. cut them out and fill them smooth. whatever floats your boat if you think its worth it.
Re: // How can I remove this ??? (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae »</TD></TR><TR><TD CLASS="quote">
they look like this
Thanks, I do like the plug idea better
they look like this
Re: // How can I remove this ??? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">If its illegal to have no front plate in fl, I would keep it on.</TD></TR></TABLE>
I would just keep the plate where it is, because if you re-locate it and put those plugs in IMO its going to look like ****.
Get some plugs, put the plate under your seat or in your trunk, next to a pack of license plate screws. If a cop pulls you over, tell him you were going to do it when you get home. Not sure if it works or not though.
Re: // How can I remove this ??? (SiYouLater)
couldnt find th plug so i just took a license plate bolt screwed it in, cut the head off it then fiberglassed over it apaint then primer
i also do that hwne im filling in holes that i dont need under the hood when i shaved my bay of course i cut the bolt head off then welded it then ground at it then finall fiber glassed everything primered and painted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">Get some plugs, put the plate under your seat or in your trunk, next to a pack of license plate screws. If a cop pulls you over, tell him you were going to do it when you get home. Not sure if it works or not though.</TD></TR></TABLE>
great idea just dont get pulled over twice
Re: (dem0nk1d)
Or you could just put the front license plate in your windshield in the bottom driverside corner they wont pull you over I've been driving like that here in NJ for the past 3 months now with no problems. They dont need it they dont read the front plate anyway unless its sitting in a parking lot.
Re: (Jhonny Ricer)
We only get on plate in florida and it goes on the rear. I still need to stop by honda and check out if i can get thoose plugs painted from them. Ill keep ya posted.
Re: (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer »</TD></TR><TR><TD CLASS="quote">You can buy them here on H-T already painted in the FS forum.
I'll see if I can find the thread.
cool thanks, Ill do some search on here to see if i can find someone selling it.
Re: (Team RS2)
i cut mine out with a bullet grinder, put masking tape acrosss the front and filled it with duramix from the back. then while the duramix was still pliable we stuck the duramix nylon tape across the back. once it dryed we pulled the masking tape off the front and filled a couple of pinholes with body filler, sprayed it with sealer and painted it like normal. now you cant tell they were ever there.
Don Jefe
03-13-2004 12:27 PM
