99 si interior conversion problem
Im helpin my brother convert his 98 dx interior to a 99 si interior. We put everything in, the whole interior harness and everything, and now the fuel pump wont kick on. Any tips on how to trouble shoot this? (the fuse is not blown)
Re: 99 si interior conversion problem (Throwdown)
i dont think its the main relay because we have the new one and the old one and we tried both. has anyone else done this conversion who can chime in?
Re: 99 si interior conversion problem (k624ash)
do you hear the fuel pump prime before you turn the motor on? check the connections at the fuse box under dash, make sure the harness close to the drivers seat is connected completely (i had a short here when i swapped harnesses), and check the connections on top of the fuel tank, make sure they are all tight and snug
Re: 99 si interior conversion problem (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae »</TD></TR><TR><TD CLASS="quote">do you hear the fuel pump prime before you turn the motor on? check the connections at the fuse box under dash, make sure the harness close to the drivers seat is connected completely (i had a short here when i swapped harnesses), and check the connections on top of the fuel tank, make sure they are all tight and snug</TD></TR></TABLE>
i did recheck the connections on top. it doesnt prime. i guess i will recheck all the wiring to the fuel pump
any other ideas?
any other ideas?
open up the wires and check the wirings. check the ground wire. maybe the ground wire is not connected. thats what happen to me when i was doing my fog lights. Ground wire came off. i put in a new relay too. so it must be the ground wire
Re: (ikillradio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikillradio »</TD></TR><TR><TD CLASS="quote">did you do a full dash swap? and manual to electronic vent swap etc etc? could have messed something up</TD></TR></TABLE>
yea, it was a full dash swap. im pretty sure we did mess something up, haha.
1 Post
Re: (k624ash)
the 99 floor harness doesnt directly connect to any of the 98 harness' or anything so you obviously had to repin the plugs or do a cut and splice job. simply put something was screwed up or if you used crimp connectors then you have a bad connection.
double check everything and i bet you find the problem. mainly the large clip where the floor harness connect to the front cabin harness.
you should have a crash sensor and if that sensor went off it disconnects the power to the fuel pump. with the key in the on position check for power at the fuel pump. if theres no power then the sensor probably went off and you have to reset it.
Re: (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">the 99 floor harness doesnt directly connect to any of the 98 harness' or anything so you obviously had to repin the plugs or do a cut and splice job. simply put something was screwed up or if you used crimp connectors then you have a bad connection.
double check everything and i bet you find the problem. mainly the large clip where the floor harness connect to the front cabin harness.</TD></TR></TABLE>
we replaced the whole interior harness, we changed everything, dashboard and all. everything plugged right in.
we checked for power to the pump, all the sensors were getting power but the actual pump wasnt.
how do i reset this crash switch? the car that all of this came from was in a pretty bad accident
efordieforlife
14
05-18-2012 07:33 PM
EK FLY
37
02-24-2007 03:33 PM
frost_0ne
09-13-2005 01:02 PM
