D16z6 parts
D16z6 parts
I busted a rod bearing in my D16z6 and i need a new crank rod and bearings? anyone know where i can get those parts upgraded so it wont happen again? and if anyone knows where i can get something to regulate my fuel beacuse i am not getting enough fuel to the engine.
Re: D16z6 parts (theERAisBack)
most performance places will sale a fuel pressure regulator . i have a b&m regulator and it works great. if you dont want that to happen again , i would honestly begin building the bottom end for whatever you plan on using it for. if not....junkyard, honda, or ebay.
goodluck
goodluck
Re: D16z6 parts (nicks-eg6)
i have a fuel pressure regulator but i need something else because i have a turbo and my compression is higher but just look at junkyard for parts, will the stock parts be safe for it?
i dont right now. uuuummm fuel pump , injectors , and fuel rail should solve gas issues. a pull-a-part or salvage yard should have a 94 ex lying around . if you can try and find the entire motor, take it . that way you can start doing the headwork and building the motor with hardly no down time
kaiem
05-01-2019 01:01 PM
drumandbass1972
03-23-2011 07:13 PM
