92 hatch roof?
92 hatch roof?
this might sound dumb but i have been told the roof of the 92-95 hatch bolts off. does anybody know if this is true?if so would it be possable to swap roofs with a hatch that had a sunroof?i know i will need the wiring to but thats not a problem. thanks everybody
Re: (ghostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostcivic »</TD></TR><TR><TD CLASS="quote">are they spot welds or is it a solid weld? do u think aftermarket sunroof would be easer? witch would look better?</TD></TR></TABLE>
Spot welded, if you look around you will see threads of people putting sun roofs in. Its not an easy task.
Re: (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks »</TD></TR><TR><TD CLASS="quote">
Spot welded, if you look around you will see threads of people putting sun roofs in. Its not an easy task. </TD></TR></TABLE>
anything dealing with drilling out spot weld is not easy. IMO, the op should just leave the roof alone. it's not worth the trouble.
there are drill bits that you can purchase at..... sears i think???...... that will do a better job of removing the spot welds, leaving more metal to weld to.
BUT, imho if you are not very skilled with body work (welding, drilling, painting, sanding, etc.), this would not be a task that i would attempt to accomplish without professional help.
Re: (DeucesWild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeucesWild »</TD></TR><TR><TD CLASS="quote">there are drill bits that you can purchase at..... sears i think???....</TD></TR></TABLE>
If you don't get a good bit, its going to suck. There is a thread about this in the welding section.
Re: (RCautoworks)
search the archives - there's a guy that did the 92-95 sunroof swap - detailed pics of the removal and donor swap..
it's not easy but IMO it's worth it -- i would do if i could
i might be listed under "sunroof"
you have to search for a while....
jxhxb
12-20-2007 12:51 PM
