how to get in del sol trunk when locked out?
Old 09-15-2007, 07:53 AM
k0rupt_ed's Avatar
Default how to get in del sol trunk when locked out?
Ok I have a 93 del sol and I can't get in the trunk, give me anyway possible to get in there I don't care about the key cylinder because I plan on replacing it anyway
and no, theres no trunk latch for the people that don't no.
Old 09-15-2007, 08:03 AM
sicksol1994's Avatar
Default Re: how to get in del sol trunk when locked out? (k0rupt_ed)
bad new bud you can do one of two things either bust out your pass taillight and reach around OR used a hack saw and have someone pull the truck up a bit and cut the striker off the truck the part is 18.00 at honda alot cheeper than a taillight i just got done with the same issue
Old 09-15-2007, 08:39 AM
k0rupt_ed's Avatar
eck gotta be something less damaging than that
Old 09-15-2007, 08:42 AM
Ek Forever y0!
Libertariat's Avatar
Default Re: (k0rupt_ed)
You could take a 1/8" drill bit, drill some holes into the lock cylinder (just to weaken it), and then hammer it in with a screwdriver.
Is it busted and your key wont turn it?
Old 09-15-2007, 09:18 AM
k0rupt_ed's Avatar
key wont open it, can i drill right thru it then pop it with a screw driver? heard that somewhere..
Old 09-15-2007, 11:21 AM
k0rupt_ed's Avatar
pulled the cyclinder out and great nothing behind it sso i got a big hole and no poppy the trunk lol now what
do I cut up my garnish?
Old 09-15-2007, 11:40 AM
USDMCIVICHATCH's Avatar
just cut the $18 striker like the other dude said
Old 09-15-2007, 11:46 AM
k0rupt_ed's Avatar
cant lift it high enough
Old 09-15-2007, 11:59 AM
stock_honda_coupe's Avatar
There should be a rod attached the cylendar you just punched out that will unlock the trunk.
Old 09-15-2007, 01:37 PM
You gotta get two people to pull up on it I PROMISE i had 3 diff body shops and the honda place and my race team lead the only way is to cut the striker
bochekmeout
03-07-2014 11:57 AM
KodSol
01-19-2012 02:41 PM
craven160
04-07-2011 12:41 PM
Sonia's Driver
01-19-2011 05:37 AM
k7q
17
07-19-2006 11:26 AM
Quick Reply: how to get in del sol trunk when locked out?
