Spring Pin Help
Spring Pin Help
I am trying to put my shift extension back on and i have the old spring pin. Can i just reuse it or do i have to go to get a new one? And if i do where do I get one at? When I Get one how easy is it to reinstall it.
Re: Spring Pin Help (tx95excoupe)
Honda reccomends replacing it - it's only a few bucks, might as well, especially if you had the original one on there. But it probably won't make a difference if you reuse it.
Its about as easy to get on as it is to get off. I'd reccomend using a c-clamp to help get it in - tighten the clamp around the pin, hit the clamp with a hammer, retighten, repeat. Worked better than just a hammer for me. Just make sure its a cheap clamp that you'll never need again. Harbor Frieght FTW!
Re: (JayKayNidas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas »</TD></TR><TR><TD CLASS="quote">Replace that bitch. I have used a used one when putting back on a shift linkage and theres a big *** difference. Get a new one from Honda. For like $2.</TD></TR></TABLE>
what kind of difference do you notice, because i had to reuse the old one...i couldnt get one at 5pm on saturday..so i had to reuse it, and so far i dont see a difference.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">The tighter the spring pin, the less slop there is in the shifter.</TD></TR></TABLE>
Yeah, that's why I replaced mine when I swapped trans's.
I really have no clue why so many people have a problem with this thing .
Unceasing Measure
Re: (tx95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx95excoupe »</TD></TR><TR><TD CLASS="quote">well so far i dont notice a difference in shifting.</TD></TR></TABLE>
If you put the same pin in the same linkage, it's going to be the same as it was before you replaced anything If you install a new spring pin - one that hasn't been compressed by thousands of miles of driving - it'll probably tighten up the shifter a bit and keep it from wobbling around as much when in gear.
kylefrags
Honda Civic (2006 - 2015)
03-27-2018 06:34 PM
BDogggUT34
02-11-2005 03:46 PM
