HELP with timing belt
Hi, i have a b18c5 and i installed skunk2 pro series stage 1 cams, and i am having a bit of trouble with the timing belt. i can not get it to have enough tennsion on it. it will have tension on the right side then it will swithch to the left side. any help would be much appriciated. thanks
make sure you have the right belt first off. as long as it is the correct belt and you loosened the tensioner, the belt should just slide right on.
Re: HELP with timing belt (B18C5_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hittnthebz »</TD></TR><TR><TD CLASS="quote">make sure you have the right belt first off. as long as it is the correct belt and you loosened the tensioner, the belt should just slide right on.</TD></TR></TABLE>
I don't think you quite get the question, but then again, I don't think I am understanding either.
-Shane
-Shane
just changed my timing belt.......to get tension everywhere....leave the tensioner bolt semi lose(the spring automatically puts tension on the belt and that bolt holds the tensioner in place....so it holds the tension).......so leaving that bolt semi loose, turn the crank for a rotation then tighten the bolt....after you do that there should be tension everywhere..........KEEP IN MIND that i'm not sure if that's the correct way to do it but it worked for me and i've had no problems since i changed it 2K miles ago.....
plus a bump for more advice to help the guy out
Re: HELP with timing belt (rivaladore)
thanks. that helped a lot. i finnally figured it out, and then i found i didnt have compresion on # 2 cyilinder, could that mean i bent a valve.
slide inside
10-22-2009 09:25 AM
JDMs1eeper
01-10-2006 04:11 PM
JDMs1eeper
01-10-2006 04:01 PM
accordredliner
06-15-2005 10:21 AM
