Y8 CAM
ok thanx i have a mini me and i have a a z6 head on a zc bottom and i was jus makin sure it wouldnt screw nothin also its a stock cam regorund to a stage one wit oem specs that shouldnt be a problem rite
Re: (Team ICU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team ICU »</TD></TR><TR><TD CLASS="quote">ok thanx i have a mini me and i have a a z6 head on a zc bottom and i was jus makin sure it wouldnt screw nothin also its a stock cam regorund to a stage one wit oem specs that shouldnt be a problem rite</TD></TR></TABLE>
How is it a stage 1 with OEM specs? If it's a stage 1 then it's not OEM spec...?
Doesn't matter, i looked this up in the helms not too long ago - the Y8 cam has a slightly longer lift duration (either longer or higher, forgot) - either way, it's a slightly more aggressive cam.
Re: (Team ICU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team ICU »</TD></TR><TR><TD CLASS="quote">oh ok well its a stage one my bad and do i need to change anything or is it a direct swap</TD></TR></TABLE>
Should be just drop in, bro...
Might wanna change the seals and the valve cover gasket while your down there though.
