adjust the clutch pedal
i need to adjust the clutch padal in the 93 civic dx i got a b16a and i bleed the slave cyl and it still catches all the way at the top. somone told me that there are 2 bolts that i can tighten on the pedal and it will get tighter. help me
searching would have told you...
At the top of the clutch pedal there is a lock nut, undo it and spin the clutch rod until the pedal engages at a different spot.
A little goes a long way and you will screw it up a few times before you get it right
Stonage07
03-06-2017 11:48 AM
jdmcivicferio
11-12-2003 06:02 AM
