CEL help please
Old 09-14-2007, 12:46 PM
n9tkd9's Avatar
Default CEL help please
I have a 99 civic coverted obd-1 (don't know if it matters) and I have a CEL after about 15 mins of driving. I tried getting the code thru the 2 pin plug. It came out as a blink that goes off about every 2-3 secs. I know long blinks are about 1 sec between each, but does that mean its code 0 or 1? hopefully someone can help me out with this please. thanks.
Old 09-14-2007, 12:48 PM
crazyguy's Avatar
Default Re: CEL help please (n9tkd9)
and CEL goes away when u start the car next time ,right? and it will come on once the car is at working temp,right? what kind of ecu are u running ?and engine ?
Old 09-14-2007, 12:51 PM
n9tkd9's Avatar
Default Re: CEL help please (crazyguy)
yes, it goes away everytime I restart the car. I have a Chipped P06 w/Vtec on a 99 Si B16.
Old 09-14-2007, 12:53 PM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n9tkd9 &raquo;</TD></TR><TR><TD CLASS="quote">yes, it goes away everytime I restart the car. I have a Chipped P06 w/Vtec on a 99 Si B16. </TD></TR></TABLE>
i was first thinking it might be your knock sensor but since u have a chipped p06 ecu..it eliminates the knock sensor detecting...
are all the wires connect correctly? no loose wires? the ground wires are good ?
u run the CEL check when the car is running ,right ?
Old 09-14-2007, 12:56 PM
n9tkd9's Avatar
Yes, because it doesn't usually come up when started only after driving awhile so I ran it as soon as it comes up. I was told either its my harness have loose connection with harness wires or my o2 sensor? does that sound right?
Old 09-14-2007, 05:46 PM
n9tkd9's Avatar
I reran the code once it came back on again, it was about 50+ long blinks? after so many, I decided to stop. Does the code repeat itself? Any help would be appreciated, thanks.
Modified by n9tkd9 at 1:04 AM 9/15/2007
Old 09-14-2007, 09:05 PM
n9tkd9's Avatar
bump
Old 09-14-2007, 11:13 PM
MADMAX_zero's Avatar
It sounds like code 1 for the O2 sensor.
It comes on during cruising if the ECU cannot correct the fuel trim enough to get it back into stoich or near 14.7 AFR.
Who put the bin (program) in the ecu or what bin is in it?
Most of the time those spoon, mugen, etc bins are crap and way off on the fueling, so you'd have to disable the O2 sensor in the bin cause the code only allows for so much +/- correction to get the fueling to stoich.
PM me if you want a nice bin. I have plenty from tuned N/A cars.
Old 09-14-2007, 11:42 PM
n9tkd9's Avatar
Default Re: CEL help please (MADMAX_zero)
It's kenji chipped tuned ecu. I'm going to replace the primary o2 sensor tm and see how that goes. Thanks for all who helped
B16'D DA9
06-17-2016 11:41 PM
playlife
12-16-2011 08:22 AM
CRX MASE
08-23-2005 01:17 AM
92civeg
12-21-2003 03:28 PM
sshaikh01
11
05-23-2003 10:28 AM
Quick Reply: CEL help please
