d16y8
if na is ur thing then get a nice cam. gude used to make some badasss ones. im not sure if this trick works on the y8, but on the z6 u can put a b series throttle body on there and injectors (cheap mods but a cam will make a big difference.
Re: (SoCal B18b 4dr)
I've answered this question like 3x in the last 2 days.
"getting more power out of my SOHC" is one of the most commonly asked questions.
Just search (big red button in upper right corner) - it's been covered MANY times. There is NO lack of information about this topic. It's been asked and argued over many, MANY times.
As Mike (Archidictus) would say:
"Boost or nothing"
The I/H/E is all useless crap and not worth the $, you put a DC Sports header on it, you put an AEM V2 on it, you put a Apexi Exhaust on it.
Congrats you spent damn near 1k in performance parts and you're gaining a grand total of ~15whp (tops).
Boost or leave it.
EDIT:
PS: In my personal opinion when you build a D all motor to say ~160whp (which can be done for the price of a GSR swap...and can beat the GSR swap), it becomes "iffY" in terms of streetability.
You're talking about a really high comp setup and probably a cam that overlays a bit. The "streetability" becomes "iffy."
That's just my personal opinion on it though.
Y'kno, race cars and daily driver's don't mix - you can't daily drive a 2 speed power glide 1500whp camaro - same deal here when you put that much power all motor into a D.
So boost or just leave it man, you can throw together a NICE turbo kit for 1-2 grand and run it fly on stock internals. GSR eater .
"Boost or nothing"
Boost or leave it.
EDIT:
Re: (Syndacate)
https://honda-tech.com/zerothread?id=335078
Have fun, search, So on and So on read up sir
Re: (maxxd97)
Boost is the ONLY way to make power on the D-series. Syndacate spelled it out for you.
What's your budget like? I can try to help you piece together a build if I know what numbers you're playing with. If you want to go cheap, I have a few T25s, matching manifolds, and dsm side mounts for a stock-internals build. I can let go dirt cheap; but I recommend you just spend the money and build your bottom end+bigger turbo.
Re: (BrakeDanceJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">I've answered this question like 3x in the last 2 days.
"Boost or nothing"
Boost or leave it.
EDIT:
So boost or just leave it man, you can throw together a NICE turbo kit for 1-2 grand and run it fly on stock internals. GSR eater .</TD></TR></TABLE>
very nicely put
that quote should be a sticky at the VERY top of the HT so that people dont need to ask anymore.
"Boost or nothing"
Boost or leave it.
EDIT:
very nicely put
Re:
If you are smart you have one option and one option only... turbo. And since you are in CA your only option is to purchase a CARB certified turbo kit, such as Edelbrock (most complete), Greddy, and like I always mention... Drag (heard they have CARB cert kits - check it out).
Going N/A on a SOHC is going to cost a lot more (vague description I know) to get the same whp as you would by turbo'ng it. And Im guessing this is your DD, which would most likely make it pretty uncomfortable to drive depending on your whp mark. In any event, getting power N/A out of the SOHC and still passing CA smog regulations is pretty much out of the question.
Do yourself a favor, stop spending money on useless bolt-ons and invest in a good turbo set up
WanderingSamurai830
12
02-21-2007 02:50 PM
Shocka1998LX
07-07-2003 09:22 PM
