Honda Access Visor Install
I was installing my visors I got off ICB and I've run into a little problem. Brackets 'B' that go at the ends of the door seem to have a bit of a gap.
Here are a couple pictures...
and the other side by the mirror
and this is the package with part number
I'm installing these on a 1999 Civic Si coupe.
Any suggestions?
Any suggestions?
i didnt have to make slits...if you take your time on each side it comes out completely perfect. Honda wouldnt make something that wouldnt fit right.
the driver side i did was sloppy and had gaps...so i took my time with a screwdriver to hold down the visor and put the trim back on adn screwd it in looks absoulttely perfect.
so i went back and took my time on the driver side and came otu perfect no cuts/slits nothing
just take your time...and make sure when you put the trim back in the brackets are in.
if you guys need ill take pictures on how flush my sits with no cutting.
oh ya with the brackets you screw on you just have to use a lil force to push it down and screw it in. i put a lil lube on my screw driver tip so i could slide it across the trim so it goes in perfectly.
see how from teh front you can barely even tell its there. sorry these are the only pics i have of right now but like i said if you want i can take upclose ones to see how they shoudl fit with no cuts.
kaluwa3
37
10-30-2016 12:09 PM
acagemelo
Honda Fit
05-04-2010 11:07 PM
soulassassin13
03-27-2009 11:40 AM
