94 Honda Del Sol - Brake Lights stuck on
All the sudden today my brake lights will not go off even when the car is off. I have tried pulling fuses - to no avail. The only way I managed to get them to go off was to disconnect the negative battery cable.
Any ideas??
I have read places that talk about checking the brake pedal switch to see if it is stuck but I can't seem to find it. Anyone know exactly where it is and what it looks like... or what else I can try??
I am most definitely a novice. But would really rather not go to a mechanic right now as money is tight.
Any ideas??
Re: 94 Honda Del Sol - Brake Lights stuck on (sofro123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sofro123 »</TD></TR><TR><TD CLASS="quote">All the sudden today my brake lights will not go off even when the car is off. I have tried pulling fuses - to no avail. The only way I managed to get them to go off was to disconnect the negative battery cable.
Any ideas??
I am most definitely a novice. But would really rather not go to a mechanic right now as money is tight. </TD></TR></TABLE>
ok, easy fix. you need to get under the dash from the driverside (get a flash light sometimes it can be dark down there).
now the switch is located on the ugly pedal bracket that the pedals are mounted to.
link:
http://www.thehondapartsstore....ch=no
look for item #17. that is what the switch looks like.
sometimes they need adjusting (the nut on the switch), sometimes the toggle gets stuck, or worse case scenerio the connection inside the switch is bad.
they run for about $5 at the junk yard.
Any ideas??
link:
That happened to me as well. It happened because my rear brake seal went and i was out of brake fluid. Check your brake fluid. Just throwing that out there.
Re: 94 Honda Del Sol - Brake Lights stuck on (zachattack54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zachattack54 »</TD></TR><TR><TD CLASS="quote">That happened to me as well. It happened because my rear brake seal went and i was out of brake fluid. Check your brake fluid. Just throwing that out there.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solattack77 »</TD></TR><TR><TD CLASS="quote">i agree with zach above me. Thats happened to me a few times in the past 4 months. Check the fluid </TD></TR></TABLE>
he is saying his brake light is staying on, not the brake light in the dash, but the actual brake lights. being low on brake fluid will not do this.
I know this is an old thread, but I'm having a similar issue. The brake lights on my Del Sol come on with the parking lights. I've replaced the brake pedal switch already. That seemed to work for a little while, then it started happening again.
It seems like the brake lights are getting electricity from somewhere other than their normal circuit. I've taken the interior apart to examine the wiring, but nothing obvious is standing out.
Anybody have any ideas about fixing this?
Thanks,
Yoyo
Thanks,
Yoyo
i had this problem on my accord and me sol i jus super glued a pennie to the brake pedal leg where the brake switch hits. worked perfect.
Thanks,
Yoyo
Thanks,
Yoyo
It's not the switch or the stopper, I've replaced the switch and the lights do work properly as long as the running lights are off. I thought it may be a bad ground also, but I can't seem to find the ground wire in the trunk or the side frame. Does anyone know where the brake lights/tail lights ground is?
Thanks,
Yoyo
Thanks,
Yoyo
I found the problem. In the tail lights, one of the filaments had broken and shorted out with the other filament inside the bulb. When the lights where on, the brake lights got power through short in the bulb itself. That was a pain to find. I can't imagine what the chances of that happening are.
Yoyo
Yoyo
I found some disintegrated plastic pieces on the floor mat after a kid at the tire store kicked around down there (always tell them to be gentle with a '93 Del Sol!!!) near the brake pedal.... It was the Brake Pedal Stop Pad..... about $5-7.... Very likely is this....
11 year old thread, users probably not around anymore.
Morgana Invictus
09-21-2008 10:28 AM
Kalokohan
07-14-2006 10:50 AM
solbats
14
09-06-2004 03:18 PM
