1995 Civic Engine turns off
When driving my civic, after about 20 minutes, the check engine light flashes, and the engine turns off. I then have to wait about 15 minutes, and the car will turn on agian. Any ideas?
Re: 1995 Civic Engine turns off (berttheraider)
something is probably clogged.check your ecu like dcsport said! maybe too lean fuel/air mixture. or too heavy. or the spark plugs arent working.
[QUOTE=berttheraider]When driving my civic, after about 20 minutes, the check engine light flashes, and the engine turns off. I then have to wait about 15 minutes, and the car will turn on agian. Any ideas?[/QUOT
My Eg did this.It was the dizzy. would start up and drive for about 15mins and then shut down.And check your main relay as well.
Modified by LSR-Abuser at 10:11 PM 2/17/2008
go to autozone, or find the 2 pronged plug in the passenger kick panel, its not plugged into anything. stick a paper clip in it to jump the two sides. count the flashes, they will be long blinks, then fast ones. so if it does 3 long and 4 fast, thats 34.
