95 civic motor swap help!
i got a 95 hatch CX and was wondering have anyone droped a obd2-a wiring harness into the car to wire up a 96 GSR motor? if so let me know and give me some input if it wires straight up! or should i stay with OBD1 and rewired vtec!!! let me know guys, need to know this before i start buying parts to put the long block into the car
Re: (BlueIntegraBoy)
thanks man but i was just wondering if i was to use the reg. obd1 engine harness in my hatch (CX) it would connect to all the sensor on the GSR or do i have to switch out some sensor on the motor? i was told i needed to switch out a few on the motor.
Re: (EKLIS)
Humm never knew OBD1 harness will plug into a OBD2 harness
Just use ur CX harness and add in the vtec. Everything will plug right in, you might need to switch a sensor or two.
Re: (gourley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gourley »</TD></TR><TR><TD CLASS="quote">Humm never knew OBD1 harness will plug into a OBD2 harness
Just use ur CX harness and add in the vtec. Everything will plug right in, you might need to switch a sensor or two. </TD></TR></TABLE>
it will!!! obd2 integra harness will plug straight up to the the factory 92-95 civic shock towers. and the cx car is already wired for vtec the only thing you need to wire is the iabs and your good to go.
Re: 95 civic motor swap help! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">.......knock sensor, and IAB from the strut tower to the ECU plugs.
I have 94 Civic SI.... with a USDM OBD1 GSR going into it. I know i have to wire up the knock sensor and IAB. But do I have to mess with any of the other pins? A20?
Re: (EKLIS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKLIS »</TD></TR><TR><TD CLASS="quote">thanks man but i was just wondering if i was to use the reg. obd1 engine harness in my hatch (CX) it would connect to all the sensor on the GSR or do i have to switch out some sensor on the motor? i was told i needed to switch out a few on the motor.</TD></TR></TABLE>
You'll need to do the distributor conversion harness when using a obd1 harness, b/c the obd2 dizzy connection is 2 connectors and obd1 is 1 connector. Theres another too, i think the injectors.
Re: (z6hatchboy)
ahh i see now, so most likely i would need to drop in the (CX) wiring harness and just wire it up that way and whatever plug don't fit the GSR motor just switch it out? i got all the other wired inside the car wired up for vtec and knock senor and all that!!! so i just need a OBD1 wiring harness?? and wire it up that way, and switch out the sensor that doesn't plug in?
Re: (EKLIS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution »</TD></TR><TR><TD CLASS="quote">
it will!!! obd2 integra harness will plug straight up to the the factory 92-95 civic shock towers. and the cx car is already wired for vtec the only thing you need to wire is the iabs and your good to go.</TD></TR></TABLE>
YES!! 96-99 Integra harness will plug up perfect to any 92-95 civic. Do not use your crusty Cx harness with the single wire 02 sensor. Use the Integra engine harness!!!!!!!!!!!
However the ONLY civics that were prewired for vtec are all 92's and 92-95 Si's and Ex's, his 95 Cx is not prewired, he would need to run all the stuff Blueintegraboy said from the shock tower to the ecu!!!!!!
Re: 95 civic motor swap help! (HatchbackSqueegee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchbackSqueegee »</TD></TR><TR><TD CLASS="quote">
I have 94 Civic SI.... with a USDM OBD1 GSR going into it. I know i have to wire up the knock sensor and IAB. But do I have to mess with any of the other pins? A20?</TD></TR></TABLE>
Anyone have an answer for this one?
no you don't have to mess with the other pins
Re: (civ95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ95 »</TD></TR><TR><TD CLASS="quote">z6hatchboy This man is 100% Correct </TD></TR></TABLE>
about what?
about what?
Re: (USDMCIVICHATCH)
i got another question does anyone have a diagram or know where the OBD1 GSR wiring harness attach where on the engine bay! i located a couple! needing help on that thanks!
RC_Benjamin
03-14-2006 05:44 PM
fckmnky69
03-04-2005 09:50 PM
00ITR-0723
11
02-10-2004 10:18 PM
