00 ls into a eg coupe.....
i just put in a 00 ls complete swap into my eg its my first swap so i wanted to know if these things r normal sometimes a strong smell of gas comes into the car and out side 2 i run out of gas quicker 2 the swap was in my integra and it didnt do none of this b4 also no check engine and my fan wont turn on wat can it b and iam running on a b16header is this okay ?? need help asap thanks
Re: 00 ls into a eg coupe..... (p3terson17)
check if there is a gas leak on the fuel filter .injectors..and yes b16a header will bolt on to b18b block.but the downpipe flange will be off. cause b16a and b18b has different flange angles. fan wont turn on? which fan? radiator fan or ac fan? what ecu are u running
1 Post
Re: 00 ls into a eg coupe..... (mcvtec)
just hotwire ur fan switch to come on with ignition...
and check ur fuel filter in engine bay along with injectors like that other dude said an u should be ight... loose fuel filter lines make ur whole inside smell like the strongest gas smell, it happened to one of my homeboys....
Re: 00 ls into a eg coupe..... (JDM_SOHC)
how do i wire the fan 2 come on with the ignition i have connected straight to the battery and it sucks every time i stop the car i gotta open the hood and disconect and iam running on a ls ecu thanks for the replys
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3terson17 »</TD></TR><TR><TD CLASS="quote">how do i wire the fan 2 come on with the ignition i have connected straight to the battery and it sucks every time i stop the car i gotta open the hood and disconect and iam running on a ls ecu thanks for the replys </TD></TR></TABLE>
i did it like 2 years ago but something along the lines of just splicing the wires together...
certain year eg's have different size fittings on the fuel rail...pick up new crush washers and nut for the teg rail. fyi...gas is flammable, please dont tell me youre still driving even when it smells like gas
Re: 00 ls into a eg coupe..... (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">certain year eg's have different size fittings on the fuel rail...pick up new crush washers and nut for the teg rail. fyi...gas is flammable, please dont tell me youre still driving even when it smells like gas</TD></TR></TABLE>
LMAO speedy, u kill me.
Yea, id check the fuel rail for leaks, also check under the car while its running for anything dripping then follow it to the source.
Re: 00 ls into a eg coupe..... (gourley)
can some 1 post a pic where i should b looking at cause when i check the fuel lines going to the injecters it seems fine its not wet r nothing can it b a leak some where else r something else cause when i rev the car its smells like gas and also iam wasting gas like crazy like 15$ a day and the most i do is like 5-10 miles a day
also iam running on a stock fuel pump does that matter ????
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3terson17 »</TD></TR><TR><TD CLASS="quote">also iam running on a stock fuel pump does that matter ???? </TD></TR></TABLE>
negative...
negative...
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p3terson17 »</TD></TR><TR><TD CLASS="quote">can some 1 post a pic where i should b looking at cause when i check the fuel lines going to the injecters it seems fine its not wet r nothing can it b a leak some where else r something else cause when i rev the car its smells like gas and also iam wasting gas like crazy like 15$ a day and the most i do is like 5-10 miles a day
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">gas is flammable, please dont tell me youre still driving even when it smells like gas</TD></TR></TABLE>
So you are driving it, spreading fuel all over the Bronx. I hope you have fixed it, that is major fuel loss and it shouldn't be that hard to locate the source of the leak.
1 Post
yeah dude thats definitely a significant fuel loss, you should MOST DEFINITELY be able to see where that ***** comin from...
worst case scenario, just throw a match under ur car an see where the trail of flames starts from... than sit back an watch the fireworks, with the better state of mind since u now kno what was causing it...
