ls knuckles and brakes... which axles question
i just bought a 94 del sol shell that is set up for a b series motor and it also has ls front brakes and knuckles. now im thinking of dropping in a single cam motor so what axles could i use or do i have to change the knuckles? and if i change the knuckles is there any way i can keep the ls brakes? please help me out thanks!
they're all the same, you get axles for the motor not the brakes.......
you must be thinking about ef's, where you have to upgrade to fit the larger diameter axle maybe?
Re: ls knuckles and brakes... which axles question (solsi2000)
If you are dropping in a D series, you use the axles corresponding to the D series. You don't have to change the knuckles for your swap. If everything is bolted up, then you have no problem. Just double check that you have front camber kits while everything is apart.
i'm assuming since since you have ls knuckles, then you have ls rotors, hub assembly, and wheel bearing....and im not sure a d series axle will fit in that wheel bearing...i could be wrong though....anybody?
Re: (slvrlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrlude »</TD></TR><TR><TD CLASS="quote">i'm assuming since since you have ls knuckles, then you have ls rotors, hub assembly, and wheel bearing....and im not sure a d series axle will fit in that wheel bearing...i could be wrong though....anybody?</TD></TR></TABLE>
yes you're wrong.... d series is 32 mm and so is b series...92-00 civic/delsol=94-01 Integra
88-91 4spd civics have smaller
98-01 Jdm Itr=36mm
98-01 Jdm Itr=36mm
Re: (USDMCIVICHATCH)
yeah that was my question exactly.. wasnt sure if it was going to fit in the wheel bearing. so if you put a d16 into a 94 integra you just use the d series axles and your set? thanks for clearing it up.
Re: (nub)
thanks. and ive searched but does anyone know if the vtec dual core radiator will fit a single cam motor? i think the hoses are different sizes if i remember. lmk
becauseracecar8
12
07-02-2014 10:17 AM
lilsicsoul
03-18-2009 04:56 AM
