Car sometimes dies a sec after starting
I noticed that sometimes when I have the key for the fuel pump and reley to be on nothing lights up. It has also died on me while driving.
Help me.
Help me.
Re: Car sometimes dies a sec after starting (about:blank)
possibly the ignition switch... but this could be impossible to diagnose over the internet because of all the possible things that could be wrong.
Re: Car sometimes dies a sec after starting (994door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door »</TD></TR><TR><TD CLASS="quote">possibly the ignition switch... but this could be impossible to diagnose over the internet because of all the possible things that could be wrong.</TD></TR></TABLE>
I will check that, anyone else?
Re: Car sometimes dies a sec after starting (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic »</TD></TR><TR><TD CLASS="quote">check engine light?</TD></TR></TABLE>
yeah but it is on already because of the o2 sensor.
my 95 had some weird problems like this that i never figured out. i unplugged my map sensor and it ran good. so i tried replacing the sensor and had the same problem. and the voltage from the sensor was perfect. the CEL said map sensor tho. i also had an idle surge that i never figured out. i tried all the common causes and still couldnt fix it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by about:blank »</TD></TR><TR><TD CLASS="quote">I noticed that sometimes when I have the key for the fuel pump and reley to be on nothing lights up. It has also died on me while driving.
Help me.</TD></TR></TABLE>
It's your main relay bro repalce it.. you can get them new on ebay
ok guys I think it is the ignition switch, it doesn't go into position number 2. and when it is in position number 3 and I let the key go it turns off. what can be the problem? can I fix it without replacing it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by about:blank »</TD></TR><TR><TD CLASS="quote">ok guys I think it is the ignition switch, it doesn't go into position number 2. and when it is in position number 3 and I let the key go it turns off. what can be the problem? can I fix it without replacing it?</TD></TR></TABLE>
what part of the ignition switch is messed up?
what part of the ignition switch is messed up?</TD></TR></TABLE>
bump for an answer
bump for an answer
Re: (thatonekid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatonekid »</TD></TR><TR><TD CLASS="quote">Bad distributor?</TD></TR></TABLE>
I doubt it
I doubt it
