Simple MAP sensor question
I hooked a voltmeter to the vcc to a chassis gnd i get 5 volts with the key on
I have continuity from the gnd to the chassis
I hooked the voltmeter to the map output and i get 3.5 volts with the key on with or without vaccum.
The output never wants to change... so
Bad map sensor?
Looking for a second opinion before i go get a new one.
Bad map sensor?
Re: Simple MAP sensor question (kenfu)
you can check the spec in the honda hanes book.. or whatever you call it.. i have it at home.. but i wont home until friday. do you have check engine light? usually when the sensor goes bad the check engine light pops up
maybe a bad voltmeter. im not sure but i dont think the vss should have 5 volts when its not doing anything. why are you checking this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic »</TD></TR><TR><TD CLASS="quote">maybe a bad voltmeter. im not sure but i dont think the vss should have 5 volts when its not doing anything. why are you checking this?</TD></TR></TABLE>
He said Vcc not Vss. oops!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenfu »</TD></TR><TR><TD CLASS="quote">The output never wants to change... so
Bad map sensor?
Thats a Fail in my book.
Bad map sensor?
