Need advice on bleeding brakes...
I clamped the brake lines when I took off the calipers, so I figured I could just bleed the brakes a little and then top off the MC, but the pedal is pretty soft. So, now what? (yes searched)
Re: Need advice on bleeding brakes... (Torquelessb18)
get a long vaccum hose, fill clear bottle halfway with brake fluid(plastic or glass),insert hose into bottom of bottle, force hose over bleed screw open bleed screw,(make sure you can see bottle or have someone look at it for you). Pump brakes until all bubbles are gone tighten bleed screw then remove hose, check resevior fill as needed do all wheels starting with right rear,left rear,right front left front.
EJ8mike
09-10-2005 05:15 PM
willy.wonka
16
11-06-2003 02:47 PM
Milano97
04-15-2003 06:07 AM
