Swap Help
Swap Help
Alright... So I know quite a bit about dsm swaps and such but Id like to clear things up for honda swaps. I have a 99 ex witht he stock d16. If i wanted to swap to an ls motor for example... All id need are the motor and trans mounts, obviously the motor, the ecu and axles. and the wiring harness. Is that all though? To swap in a b18.. is there any fabrication needed?
You need the tranny, motor, SI rear mount bracket and i think the SI Driver side mount bracket, LS axles, LS ECU, EX harness should work, LS throttle bracket(i think), fuel line from rail to filter(i think), no fab though...i might have forgotten a few things.
